0 members (), 35 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#798104 11/15/2011 1:45 PM
Need info .The areas around the wheel well of my 58 needs body work . most of the work frome the spear up i can handle, but does anyone have a sorce for replacement meatal for around the wheel well area.Is there any other year bed that panels would be able to be removed and welded to the 58 bed [there in rough shape ] TONY
chevyman1 #798452 11/16/2011 6:32 PM
chevman1:
MAR-K has a wheelhouse repair flange. Here is the description:
Wheelhouse tub flange to repair rusted or damaged area of wheel tub where it meets the wood floor. 16-gage electro-galvanized steel flange has bed strip embossment like original. Instructions included. Requires 2 flanges per truck. Made in Oklahoma City, USA.
This should take you to the part online.
http://www.mar-k.com/Catalog/itemDetails.aspx?ItemID=100585
Hope this helps!
Mar-Ktech #799783 11/21/2011 9:05 PM
Thanks for that info. Im looking for repair panels for the out side of the bed around and including the center and sides of the outer wheel area.I can find repair pannels fo the stepside but not the fleetside .TONY
chevyman1 #799838 11/22/2011 1:45 AM
there are no patches made for the fleet wheel opening, although you could cut some from a stepside fender, which has a very close shape for the molded edge
chevyman1 #806155 12/12/2011 11:21 PM
How much of the wheel opening do you need? I am cutting up a fleetside bed to make into a dually bed. The bed I have has rust in the spear section above and behind the wheel. but is solid around the wheel opening itself. How soon would you need them? I was going to save them in case I ever needed one but that day may never come.
Shane
1959 Apache 3100 Fleetside
1959 Apache 3200 NAPCO
1957 Chevy 5700 Low Cab Forward
1959 GMC F370 LCF
Another 1959 Apache 3100 Fleetside
1959 Chevy 5700 LCF
1946 Chevy 1/2 ton
1958 GMC 600
1974 Elcamino SS
buggy5872 #806627 12/14/2011 5:43 AM
I would compare to the 60-66 sheet metal below the 'spear'. I think the wheel opening is close but I no longer have a 60-66 to check against my 59. I do have a 60-66 tailgate on my 59 fleet and it's he same. The patches are available for the 60-66 wheel openings but at a minimum you would have to take some off the top.
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
