| | | Forums66 Topics128,006 Posts1,055,268 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 74 | I have a 1948 chev and put in a one wire alternator. I ran the big wire to the starter and added a smaller wire to the ammeter then to the battery. It is reading an output around 14.60 but the needle does not move. I changed from both sides of the ammeter but the needle still does not move. Is this telling me that the ammeter is no good. Thanks | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy first48, in order for the ammeter to function correctly all the current going to charge the battery must pass through it. By puting the large wire to the battery you have effectively bypassed the ammeter, connect the large wire from the alternator to the ammeter and the other side of the ammeter to the batery or the starter power in stud, hope that helps. | | | | | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 | 3B has it exactly right. You have the ammeter effectively bypassed.
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | | | | Joined: Jul 2011 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 74 | Thank, I give it a try. You were right-- It works--Thanks | | |
