Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (51sub), 187 guests, and 7 robots.
Topics128,288
Posts1,058,578
Members48,492
#805475 12/10/2011 5:35 PM
1958 GMC 3speed transmission.original to truck.When I adjust the clutch;do I want it to start to grab about an inch from floor?Right now pedal is almost fully released before it grabs;so I know it needs an adjustment.Just been awhile-
Thanks in advance
Danny
1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
This explains how to check and adjust clutch free play.
Hope that helps.
Your looking at the wrong end of the pedal Danny, there is no adjustment for where the clutch starts to grab. The only adjustment is in the clearance at the top of the pedal which should be 3/4 to 1 inch before you feel the throw out bearing contact the pressure plate fingers.
And as Waldo points out, if all else fails, read the manual.
DG
Denny G
Sandwich, IL
Thanks 4 the help.Did it yesterday-
Danny
