5 members (51sub, Bill Hanlon, BC59, 2 invisible),
133
Mod | | | Forums66 Topics128,288 Posts1,058,571 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | 1958 GMC 3speed transmission.original to truck.When I adjust the clutch;do I want it to start to grab about an inch from floor?Right now pedal is almost fully released before it grabs;so I know it needs an adjustment.Just been awhile- Thanks in advance
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | This explains how to check and adjust clutch free play. Hope that helps. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Your looking at the wrong end of the pedal Danny, there is no adjustment for where the clutch starts to grab. The only adjustment is in the clearance at the top of the pedal which should be 3/4 to 1 inch before you feel the throw out bearing contact the pressure plate fingers. And as Waldo points out, if all else fails, read the manual.
DG
Denny G Sandwich, IL
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Thanks 4 the help.Did it yesterday-
