7 members (2-Ton, Shaffer's1950, Otto Skorzeny, Gdads51, stoveboltgator, klhansen, Rusty Rod), 91 guests, and 1 robot.
Topics128,048
Posts1,055,539
Members48,424
#80590 07/29/2007 4:48 PM
Junior Member
Junior Member
What front end will fit my 66 c-20 to make it have disc brakes? reclinerrepair@yahoo.com
#80591 07/29/2007 6:07 PM
You can use the crossmember from a '73-'87 to swap the front suspension over to get front disks and power steering. If you're just looking for the disk brakes, you could just swap the spindles fom the same truck along with the balljoints.
Bill Burmeister
#80592 07/30/2007 12:32 AM
Junior Member
Junior Member
Does it matter if it is a van or pick up. How difficult is this to do?
#80593 07/30/2007 2:16 AM
no, it can come from either. I'm no expert on doing the swap, but you only need to drill 4 holes to do it. You might do a search on the site. I know that there's several members that has done it, perhaps they can give more insight into just exactly what need to be done.
Bill Burmeister
