| | | Forums66 Topics128,024 Posts1,055,393 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#80590 07/29/2007 4:48 PM | Joined: Jul 2007 Posts: 3 Junior Member | | Junior Member Joined: Jul 2007 Posts: 3 | What front end will fit my 66 c-20 to make it have disc brakes? reclinerrepair@yahoo.com | | |
#80591 07/29/2007 6:07 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You can use the crossmember from a '73-'87 to swap the front suspension over to get front disks and power steering. If you're just looking for the disk brakes, you could just swap the spindles fom the same truck along with the balljoints.
Bill Burmeister | | |
#80592 07/30/2007 12:32 AM | Joined: Jul 2007 Posts: 3 Junior Member | | Junior Member Joined: Jul 2007 Posts: 3 | Does it matter if it is a van or pick up. How difficult is this to do? | | |
#80593 07/30/2007 2:16 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | no, it can come from either. I'm no expert on doing the swap, but you only need to drill 4 holes to do it. You might do a search on the site. I know that there's several members that has done it, perhaps they can give more insight into just exactly what need to be done.
