0 members (),
132
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I've read tech tips on bolt removal. Knowing that the rear fender bolts on my burb stand a good chance of breaking off, I'm thinking maybe I could heat them up with my mig welder first. I'm not looking forward to breaking all of them off then using the tech tip method! I have sprayed them with PB blaster, and in my first attempt to remove a bolt it broke off. Anybody else use the heat first method, got any pointers? Thanks, Phil | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | No pointers. I think I only got TWO bolts out on my panel. The rest of them twisted into with ease. Heat may help you but don't look for it to be the proverbial silver bullet. | | | | | Joined: Feb 2004 Posts: 29,852 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,852 | How can you heat bolts with a MIG welder? I've used an acetyline torch, and even a little Propane torch on small areas, but I can't imagine how a wire welder would do any heating without piling up a huge mess of metal in the process. I'd suggest giving the bolts a good warm-up with a torch, and a liberal squirt of Kroil, then heating again after a few days before trying to turn them. Jerry
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Jerry, my plan is to mig weld a bolt/rod to the head of the frozen bolt, and the heat generated by welding might free up the bolt? At least I'll have something to weld to. I can also apply additional heat with my acetylene torch. I'll report back with the results on monday. | | | | | Joined: Feb 2004 Posts: 29,852 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,852 | If you've got acetyline available, skip all the hassle of trying to spot anything onto the seized bolt. Just get out the Victor hot wrench and get 'em warm! A small heating tip like a #0 or a #1 and a needle-point flame can be controlled very nicely to just heat the bolt without doing much damage to the surrounding area. Jerry
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | With no gas I went with the mig route. I found for smaller screws assorted screw bits worked great and they were cheap expendable and easy to weld. For larger bolts nuts worked better. Just make sure you really weld it on good as that seemed to be the level of heat required to break things free.
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | The bad news, 1 for 20! So now I've got 19 broken bolts to remove. I'm thinking I might just cut out the cage nuts and weld in new nuts? The good news the rear fenders have rust but not rusted through!! Also the right side inner fender well is not rusted through, can't say the same for left side but enough metal to work with. I can't beleive how much dirt can collect inside those quarter panels!! Just think some of it is almost 60 years old. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | The bad news, 1 for 20! So now I've got 19 broken bolts to remove. I'm thinking I might just cut out the cage nuts and weld in new nuts? I feel for ya Yakima New nuts or new cages? I know you can get them but don't remember where, I made a couple up when I needed them bit I'd be buying a box if I was looking at 20 per side
| | | | | Joined: Oct 2011 Posts: 19 New Guy | | New Guy Joined: Oct 2011 Posts: 19 | personaly i have found that if i get a frozen up bolt basicaly red hot they seem to come out like butter. problem is that this is not always an option. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | yakimabowtie, remember, I only got TWO out so I win Sorry to hear that. I was hoping you'd have better luck. I was lucky. The guy who did my body work for me looked at the situation, laughed and say "no problem". I told him to have at it. He did do a nice job and replaces alot of metal. I hope you have great success. | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Update & correction, there are only 18 "cage" nuts on the rear fenders. In the process of removing the fenders I did break off 17 bolts. On the left side three cage nuts are completely rusted out. I was able to remove 7 bolts with using this method, I took a 1/4" steel rod and grind the end to a pencil point. I was able to weld the tip to frozen bolt. The remaining bolts are to recessed to reach, so I'm going to try and drill them out. Maybe this will help someone else, just hang in there, and keep working at it! | | | | | Joined: Aug 2009 Posts: 163 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 163 | Sorry I live in Arizona and this might be a stupid question, what are frozen bolts?
| | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | Frozen bolts is just another way of saying you can't undo the nut from a bolt once it has been rusted; it's frozen in place. Or simply it's stuck!
I wasn't as lucky removing the rear fenders from my Panel. They were so badly rusted I think I snapped all but one bolt.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
