0 members (),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | some time back i bought a4.3 chevy eng and trans.i would like find out what ihave.it is a 350 turbo.the only markings it has,is 1986 neatly welded on side..notags on it. any help? | | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | | | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | all iget from that is data base error,thanks | | | | | Joined: Apr 2006 Posts: 273 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 273 | all iget from that is data base error,thanks Strange, that never happened to me. Here's a link to their main page: http://www.layitlow.com/Try searching from there. | | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | fwiw,a little reserch,tells me i have a 700r4.thanks for all the help. | | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | now that i have figureed out what tranny i put in my truck,i have a couple of quistions for you guys.no 1,i am using a weber carb,what do ido for the kickdown connection.no2 on the left side of the trans. there is a square plug witf 4 wires,could someone tell me for what or where they go.anyone please.now there is something you hear an old man say very often... | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | You can get an aftermarket kick down cable for a 700R4. The adjustment is critical for the health of the transmission. The plug is for the torque converter lockup through the computer. There is an aftermarket kit available to engage the lockup without the computer. The pan has to be removed to install the conversion. Many just use the trans without the lockup. Fred
| | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | thank you fred.i will look for a kit ,for the kickdown switch..removing the pan is not a prolbem. | | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | old dummy is back.i am looseing sleep over this guys,is there away to use my 700r4 trans without useing the tv cabel?i am useing a weber carb and i cannot see a way to hook up the cabel.enlightin me more.sorry guys i am getting old... | | | | | Joined: Mar 2009 Posts: 4 New Guy | | New Guy Joined: Mar 2009 Posts: 4 | you need that cable hooked up the cable is how the trans know the engine load to rise pressure in the trans if not set right will smoke the clutchs | | | | | Joined: Aug 2011 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 149 | thanks,i refuse to bore anyone,with more quistions... | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you need to fab up what's necessary for your particular setup - a DIY project with pictures - and check around Bowtie overdrives for different kits - TV cable setupBill | | |
