3 members (Hotrod Lincoln, Chip O, Steelonsteel), 125 guests, and 3 robots.
Topics128,196
Posts1,057,391
Members48,471
I have a 51 1/2 ton it came with no door handles or lock, it has shaved door handles. They welded up the holes for the handle and lock. How hard would it be to put back my door handles. Could I just drill out where they welded up the holes and put back my door handles. Is it that simple or is their more to it. Please help thanks
My '55 1st series also had shaved exterior door handles. They did not do a good job welding the holes. I drilled the hole and used a grinder for finishing the hole requirements. Turned out great. I now have the original exterior door handles on the truck. Good luck.
Larry
Sounds good Ill have to give it a shot anyone else here might have some pics or a step by step of how they did it please share thanks
