7 members (Ponchogl, Otto Skorzeny, moparguy, KEVINSKI, Brian Moore, 55shaker, ShopRag), 71 guests, and 3 robots.
Topics128,030
Posts1,055,424
Members48,422
#80458 07/26/2007 12:42 AM
I am trying to replace my 46 216 engine with a 59 235
The 235 that I have has side motor mounts and I need it on the front, I am trying to remove the front plate from the 216 and insatll it on the 235, I am down to the timing gears? but am having issues trying to remove them. Does anybody have any ideas?
Thanks in advance and if you think I am totaly nuts please say so
grin
Ed
#80459 07/26/2007 1:06 AM
The cam timing gear is pressed onto the cam. You'll need to remove the cam to get it out. The crank shouldn't be an issue.
Bill Burmeister
#80460 07/26/2007 2:53 AM
I think that if you do a search, you wou find some data on doing it without removing the front plate. I haven't done it that way, so I don't remember how it was done.
#80461 07/26/2007 3:42 AM
I just did the same thing last year, pulled the cam out.
You never have enough, til you have too many!
#80462 07/27/2007 4:04 AM
Rotate the cam and you'll find two phillips screws that hold the cam in
I always feel better when I feel like I'm getting away with something.
1939 Chevy 3/4-Ton ~ Farm Boy
#80463 07/27/2007 12:48 PM
Thanks guys, I am going to try this over the weekend.
Ed
