2 members (Ponchogl, Gdads51), 98 guests, and 3 robots.
Topics128,128
Posts1,056,670
Members48,450
Hi!
1946 1/2ton, 216.
Wondering if anybody has any pictures/images of the linkage form the gas pedal to the car. My gas pedal seems stuck to the floor and I am trying to figure out what is going on. My manual doesn't seem to have much info.
Andy
Here you go Andy. I added a few photos and started an FAQ page with some other reference materials for 41-46 trucks. I'll keep adding to it.
FAQ page from www.46chevytruck.com
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
As for your stuck pedal - it is not uncommon for them to get stuck because the floor panel has shifted. Start by checking that. If the pedal rod is not rubbing there then I would check the pivot point on the block. Mine was stuck pretty solid. Spray it with penetrating fluid and work it back and forth until it is free.
Tim Sheridan
