| | | Forums66 Topics128,034 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 12 New Guy | | New Guy Joined: May 2006 Posts: 12 | I recently purchased a 3 speed with a Borg Warner overdrive box. I have it installed in my 55 1st series 3100. I am going to wire it up like it came from the factory with a relay and kickdown swithch. I have the wiring diagram but the solonoid on the transmission doesn't have the terminal 4 or terminal 6 marked on the solonoid case. Is there any way to know which is which so I get things wired right the frist time and not burn something up? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Why don't you post a copy of the schematic and maybe someone here could point you in the right direction.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: May 2006 Posts: 12 New Guy | | New Guy Joined: May 2006 Posts: 12 | Denny, Thanks for your response. I was looking for the schematic and actually found an answer to my question. I found a link that told which terminal was which. Thanks again.
Grant | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Reason I asked Grant was not only because you might get an answer but we might share the information with the the other 25,000 registered members of the group.
But glad you got it sorted out on your own.
DG
| | | | | Joined: Nov 2004 Posts: 266 Custom Title | | Custom Title Joined: Nov 2004 Posts: 266 | Where'd you find the wiring diagram and info for the OD? I have one too and I'll be wiring the truck in another couple months.
49 Chevy 3600 65 Chevy K10 48 International KB-1 Service Truck 55 Willys CJ5 - Chevy 331 powered 26 Model T Roadster Rat Rod 70 Tucker Sno-Cat 442-A 96 Dodge 3500 Cummins dually flatbed x-cab 4x4 06 Jeep Wrangler LJ rock crawler If you can't fix it with a hammer, it's an electrical problem | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Lots of info on that overdrive here. | | |
