| | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2011 Posts: 12 New Guy | | New Guy Joined: Jun 2011 Posts: 12 | I have an inline 6 with the numbers 3877178 C with GM under that and 25 under that, then next to it are the #'s F 14 6, then next to that is CON 2. On the flat plat behind the dist. are the #'s F0616TF can someone please tell me anything about this motor? | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | the casting number comes back for blocks used from 62-78 as 230-250 cubic inch in buick/olds/chev/pontiac/GMC.. i guess that doesn't narrow it down much | | | | | Joined: Jun 2011 Posts: 12 New Guy | | New Guy Joined: Jun 2011 Posts: 12 | Thanks Tom but that is all I could find also. I would like to know if its a 230 or 250, the horse power and anything else I can get on it. | | |
