6 members (Otto Skorzeny, R&S 51 GMC, KEVINSKI, Bill Hanlon, Swami29, Phak1), 100 guests, and 0 robots.
Topics128,125
Posts1,056,339
Members48,440
I have an inline 6 with the numbers 3877178 C with GM under that and 25 under that, then next to it are the #'s F 14 6, then next to that is CON 2. On the flat plat behind the dist. are the #'s F0616TF can someone please tell me anything about this motor?
the casting number comes back for blocks used from 62-78 as 230-250 cubic inch in buick/olds/chev/pontiac/GMC.. i guess that doesn't narrow it down much
Thanks Tom but that is all I could find also. I would like to know if its a 230 or 250, the horse power and anything else I can get on it.
