0 members (),
79
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2000 Posts: 163 | Hello!
I have obtained a front factory sway bar from a Suburban, and I'm trying to adapt it to my 1946 pickup. I have a few questions, such as how do the brackets supplied mount to the frame, and where can I purchase new rubber isolators?
Is there anyone out there that has a stock sway bar on there truck that could help me out?
Randy B. | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | You need to identify the trucks involved. Chevy and GMC used different brackets for their sway bars because of the different crossmembers. I have a sway bar on my '45 GMC.
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I have a stock sway bar with original brackets on mine, it's a '53. I don't know if they are the same as the '46s. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Randy, I'm using one of those off a panel on my 46 pickup and I'm sure I purchased new rubber parts. Don't remember whom right now, check ALL the vendors, Chevs of 40s, Filling Station etc. Best of luck
And I hope you got ALL the factory mounts and brackets. And I have a couple pics in the computer if you send me a PM. Jim
