2 members (dinosoar, 52Carl),
82
Mod | | | Forums66 Topics128,127 Posts1,056,677 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 201 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 201 | I've searched the archives and Google both. Looks like either most or at least the type I have can't be taken apart to check, clean or replace the copper mesh. It's pretty nasty in there even after a gasoline bath. Unless someone divulges this well kept secret, the Dremel tool's gonna get a workout during surgery.
Anyone? Anyone? Bueller?
'69 1/2T stepside, Sea Foam Green, 250 L6 w/ 3 on the tree, not an option on it, in the family since new.
| | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Mine was full of dead bugs and other crap. I ended up gutting it and using a dry element so I could keep the look of an oil bath. http://farm7.staticflickr.com/6236/6286050234_968eb64773_z.jpgI'll probably switch to the K&N they're using in the post you linked to once the cheap paper one I'm using reaches the end of its life. Its a cheapie Specter brand from Autozone and its supported by a rubber sleeve I picked up from the plumbing section of Home Depot. | | |
