3 members (Hotrod Lincoln, BC59, 1 invisible), 134 guests, and 1 robot.
Topics128,047
Posts1,055,538
Members48,424
#803210 12/03/2011 7:11 PM
some time back i bought a4.3 chevy eng and trans.i would like find out what ihave.it is a 350 turbo.the only markings it has,is 1986 neatly welded on side..notags on it. any help?
johnhull #803217 12/03/2011 7:32 PM
all iget from that is data base error,thanks
johnhull #803244 12/03/2011 9:26 PM
Strange, that never happened to me.
Here's a link to their main page:
http://www.layitlow.com/
Try searching from there.
fwiw,a little reserch,tells me i have a 700r4.thanks for all the help.
johnhull #804711 12/08/2011 5:43 AM
now that i have figureed out what tranny i put in my truck,i have a couple of quistions for you guys.no 1,i am using a weber carb,what do ido for the kickdown connection.no2 on the left side of the trans. there is a square plug witf 4 wires,could someone tell me for what or where they go.anyone please.now there is something you hear an old man say very often...
johnhull #805483 12/10/2011 6:16 PM
You can get an aftermarket kick down cable for a 700R4. The adjustment is critical for the health of the transmission. The plug is for the torque converter lockup through the computer. There is an aftermarket kit available to engage the lockup without the computer. The pan has to be removed to install the conversion. Many just use the trans without the lockup.
Fred
rfs56trk #805568 12/11/2011 12:25 AM
thank you fred.i will look for a kit ,for the kickdown switch..removing the pan is not a prolbem.
johnhull #819969 01/26/2012 6:48 PM
old dummy is back.i am looseing sleep over this guys,is there away to use my 700r4 trans without useing the tv cabel?i am useing a weber carb and i cannot see a way to hook up the cabel.enlightin me more.sorry guys i am getting old...
johnhull #821519 01/31/2012 4:22 PM
you need that cable hooked up
the cable is how the trans know
the engine load to rise pressure in the trans
if not set right will smoke the clutchs
johnhull #821540 01/31/2012 5:47 PM
thanks,i refuse to bore anyone,with more quistions...
jed97 #821548 01/31/2012 5:58 PM
you need to fab up what's necessary for your particular setup - a DIY project with pictures - and check around Bowtie overdrives for different kits - TV cable setup
