7 members (walterhvogel, Jman, Tom McGrath, UtahYork, Materman, Rich'sToys, Wally / Montana), 107 guests, and 3 robots.
Topics128,035
Posts1,055,557
#803078 12/03/2011 5:52 AM
a friend of mine has a 1/2 ton 51 model truck with the factory drum 6 lug brakes. The rearend has already been changed and is 5 lug. He was woundering if anyone offered drums for the front but have the 5 lug pattern. I think the rear is 4 3/4 car pattern. His plan is to change the front end out later but dont have the funds right now and wanted to try and get it on the road.
52' Chevy 6400 2 ton
Etraugott #803103 12/03/2011 12:53 PM
I don't understand. He would need 5 lug hubs too in order to mount the wheels.
1951 1 Ton Completed
truckernix #803123 12/03/2011 2:36 PM
Yes, i was thinking it the hub was built into the drum, but if they have hubs with slide on drums he would need hubs and drums for five lug. Or if there is another cheap way to get it to five lug, like parts from a donor vehicle. Im not real farmillar with these older trucks but deffenatly learning alot, so please excuse me if im not making sence.
Etraugott #803125 12/03/2011 2:42 PM
go with a disc brake conversion chevsofthe40s.com has a 5 lug disc brake conversion kit that uses the original spindles,im getting it myself
hoozat #803129 12/03/2011 3:24 PM
Ill let him know about that option too. If it were mine this is what i would do.
Etraugott #803148 12/03/2011 4:20 PM
Maybe I am mis-reading what you want to accomplish but you can just use car front brake drums to get the 5 bolt atching bolt pattern. I am told it is a quick bolt on swap as they both use the same wheel bearings.
Greg_H #803168 12/03/2011 5:00 PM
That is exacly what im wanting thanks.
Etraugott #803170 12/03/2011 5:05 PM
You need to find the hubs and drums from a 49-54 Chevy passenger car for the conversion. 55 up will not work.
Fred
rfs56trk #803237 12/03/2011 9:11 PM
Thanks thumbs_up
