7 members (Jay R, Wheelie, Gray_Ghost, Greg_H, Otto Skorzeny, 1955 1 Series, Napco Man),
137
Mod | | | Forums66 Topics128,083 Posts1,056,080 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 9 New Guy | | New Guy Joined: Nov 2011 Posts: 9 | Can anyone point me in the right direction? I want to change the steering column out to make it auto on the column. I have 3 on the tree right now, but I'm about to put in 700r4. What is the simplest most cost effective column to use? Any and all help is appreciated.....John
.....John
| | | | | Joined: Apr 2011 Posts: 16 New Guy | | New Guy Joined: Apr 2011 Posts: 16 | i recently installed a 87 suburban tilt column on my 62 c10 the wiring is fairly easy with a adapter. i got one from american autowire. i did have to remove the factory nuetral safety switch and relocate a switch to trans (ron francis switch ) I also put in a 700R4. there is a post on here with pics that a guy put on a while back. you can just search back and find it. | | | | | Joined: Nov 2011 Posts: 9 New Guy | | New Guy Joined: Nov 2011 Posts: 9 | Thanks for the info. Did you have to do any special adapter to mount the steering column? I will go back and look for that post with the pics...Thannks again
.....John
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I put a 1970 C10 column in my 63 for the auto shifter, looks right with out the ignition switch in it, Scott
| | | | | Joined: Nov 2011 Posts: 9 New Guy | | New Guy Joined: Nov 2011 Posts: 9 | That would be great. I would like to keep the key switch right where it is...Thanks
.....John
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Factory automatic column with an aftermarket shift indicator... | | |
