Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (jay d, 2 invisible), 54 guests, and 3 robots.
Topics128,009
Posts1,055,292
Members48,419
#802720 12/02/2011 2:04 AM
How many keys did an AD Panel or Burb come with? The cars had a door/ignition and a trunk/glove box so they came with two keys. Next, is there any way to remove the ignition switch if one doesn't have a key to turn the switch so the hole in the face lines up with the release button? Thank you; Evan
Evan
coilover #802725 12/02/2011 2:18 AM
One key fit everything,
if you have the glove box lock take it apart it will have the the lock number and a key can be made ,it not there should be a number on the door lock
BILL #802743 12/02/2011 3:14 AM
If you have a string of abt. 100 keys like mine. Ive opened numerous doors, ign.,trunks, glove boxes, etc with all these.
Having a key machine helps also.
coilover #802848 12/02/2011 11:51 AM
I took my locks to a local locksmith, now one key works every lock on my panel truck. Helps a lot and was well worth spending a little money
Karl54oneton #802884 12/02/2011 4:24 PM
For the ignition, you can pick it. Or you might find its worn, and any key will turn it, that's what I found with mine.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Mr. Lang #802966 12/02/2011 10:19 PM
One key fits all four locks on my suburban.Passenger door lock,Ignition switch,Glove box,Rear barn door.
Tim
1951 3100 Chevrolet
bowtietim #803086 12/03/2011 7:24 AM
Thanks everyone, I have the barn door lock out and can certainly get the door and glovebox ones out. The switch and locks all seem to be original so if they can find a number on any of the ones I take to them they should be able to cut a new one. There is a lock shop about 50 miles from me that has the two large rings of GM keys that they let me go through till one works and then make a copy. It's aways worked but if I have numbers it would sure speed things up since with my luck it's aways at least three quarters of the way through the second ring before I Bingo.
Evan
coilover #803088 12/03/2011 7:49 AM
There will be a number on the side of the passenger door lock.
1951 3100 Chevrolet
