| | | Forums66 Topics128,006 Posts1,055,268 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 24 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 24 | doing some rust repair, the 3 vertical ribs on the back of the cab found some old gunk on the back side of each rib, I was wondering if that is some kind of adhesive so the back sheetmetal sticks to the rib, any help would appreciated
thanks James | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I had similar adhesive/caulk there also. Mine was more of a 60 year old dried up piece of rubber. Unknown reason/name/usage. Maybe for vibration Dan | | | | | Joined: Oct 2008 Posts: 24 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 24 | did you replace it with anything? | | | | | Joined: Feb 2009 Posts: 23 New Guy | | New Guy Joined: Feb 2009 Posts: 23 | i had same stuff on my 46.the welds on those strips had broke at the floor so i removed that rubber type material rewelded at the floor then tack welded the strips to the back of the cab | | |
