3 members (jay d, 2 invisible),
54
Mod | | | Forums66 Topics128,009 Posts1,055,292 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | How many keys did an AD Panel or Burb come with? The cars had a door/ignition and a trunk/glove box so they came with two keys. Next, is there any way to remove the ignition switch if one doesn't have a key to turn the switch so the hole in the face lines up with the release button? Thank you; Evan
Evan
| | | | | Joined: Nov 2000 Posts: 171 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 171 | One key fit everything, if you have the glove box lock take it apart it will have the the lock number and a key can be made ,it not there should be a number on the door lock | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | If you have a string of abt. 100 keys like mine. Ive opened numerous doors, ign.,trunks, glove boxes, etc with all these. Having a key machine helps also. | | | | | Joined: Dec 2009 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 40 | I took my locks to a local locksmith, now one key works every lock on my panel truck. Helps a lot and was well worth spending a little money | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | For the ignition, you can pick it. Or you might find its worn, and any key will turn it, that's what I found with mine. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | One key fits all four locks on my suburban.Passenger door lock,Ignition switch,Glove box,Rear barn door.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Thanks everyone, I have the barn door lock out and can certainly get the door and glovebox ones out. The switch and locks all seem to be original so if they can find a number on any of the ones I take to them they should be able to cut a new one. There is a lock shop about 50 miles from me that has the two large rings of GM keys that they let me go through till one works and then make a copy. It's aways worked but if I have numbers it would sure speed things up since with my luck it's aways at least three quarters of the way through the second ring before I Bingo.
Evan
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | There will be a number on the side of the passenger door lock. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
