3 members (MickeyP, Otto Skorzeny, Lostbuthaulinass), 76 guests, and 2 robots.
Topics128,050
Posts1,055,754
#80265 07/22/2007 10:00 AM
I was just looking at an Edmunds 5X2 intake for my 270 GMC,and I see that the intake is basically a plenum chamber connected to the head by 3 bolt on elbows. Could these elbows be used as the actual manifold,without the plenum chamber? I want a 3X1 set up,but haven't seen one for the GMC engines.I'm thinking a spacer on each upright with a 1 inch tube between them would help balance the intake pulses to make them flow a little smoother. Ideas,comments?
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#80266 07/22/2007 7:02 PM
Wow - I have never seen a 5 X 2 Edmunds intake! I've seen a 5 X 1 McGurk (I've got one of those) and a 5 X 1 Howard (I've got one of those), but never an Edmunds with that many carbs. Interesting!
The idea you are contemplating is basically the idea used by Harper on their set up. The only problem I see when I look at those type of multiple carb intakes is the fact that there is no heat to the intakes, with water or exhaust. You know, of course, that cuts into the effeciency of an intake of that nature.
Joe smile
#80267 07/22/2007 11:04 PM
Can,t you get what you want in after market with hot water heat??????Doc
#80268 07/23/2007 6:55 AM
I could be wrong on the brand of manifold-maybe it was a Howard. I didn't have the actual ad in front of me.
So far I've never seen a currently made 3 single throat set up for GMC sixes. There are several available for Chevies,but none that I know of being made now for the GMC.
Not having heat could be an issue,I hadn't thought of that yet.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'84 Bronco II
'78 Dodge W-200
#80269 07/23/2007 8:31 AM
The Howard 2x5 manifold is a good design. It is actually designed to be used with either two or three carbs, most engines can't actually benefit from all 5. Why not just get blockoff plates and run it with three carbs? Larrowe & Sons sells them.
Paint & Body Shop moderator
#80270 07/23/2007 4:35 PM
The Howard I have is actually a 5 X 2 set up also. I'll bet it's a Howard you have. I think mine is a GMC intake also, since it's a plenum chamber with three elbows. I also have some block off plates to make it either a 2 X 2 or a 3 X 2.
Joe smile
#80271 07/24/2007 8:23 AM
I'm just thinking that running two barrel carbs might be a little excessive on a relatively stock 270. I thought running 3 singles progressively,or 2 singles direct might make a little more power without killing what little fuel economy it currently has. (Maybe running a single two barrel would be the best compromise.)
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'84 Bronco II
'78 Dodge W-200
