8 members (GRNHydra, David Bush, JW51, Oswald, Otto Skorzeny, Wally / Montana, Guitplayer, NJC),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,060 Posts1,055,838 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#80263 07/21/2007 10:40 PM | Joined: Jun 2006 Posts: 382 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 382 | I'm trying to figure out if my '50 3600 has the 216 in it, or a later model 6. Here are some casting #'s.....
Cyl. Head--- 3835913/GM20 913/241/570
Block--- 9836236
Exhaust Manifold--- 8335580
What has me wondering is the valve cover. It has the Chevrolet script across the top, rather than the regular "ribbed" cover. It is still running the generator & road draft tube, if that means anything. Thanks in advance for the help. | | |
#80264 07/21/2007 11:00 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Head shows as 54 and later 235, don't see that block number. Get the stamped number next to the distributor. | | |
