4 members (Fannin, 2-Ton, Phak1, TUTS 59), 170 guests, and 3 robots.
Topics128,084
Posts1,056,085
Members48,434
Can anyone point me in the right direction? I want to change the steering column out to make it auto on the column. I have 3 on the tree right now, but I'm about to put in 700r4. What is the simplest most cost effective column to use? Any and all help is appreciated.....John
.....John
i recently installed a 87 suburban tilt column on my 62 c10 the wiring is fairly easy with a adapter. i got one from american autowire. i did have to remove the factory nuetral safety switch and relocate a switch to trans (ron francis switch ) I also put in a 700R4. there is a post on here with pics that a guy put on a while back. you can just search back and find it.
Thanks for the info. Did you have to do any special adapter to mount the steering column? I will go back and look for that post with the pics...Thannks again
.....John
I put a 1970 C10 column in my 63 for the auto shifter, looks right with out the ignition switch in it,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
That would be great. I would like to keep the key switch right where it is...Thanks
.....John
Factory automatic column with an aftermarket shift indicator...
