3 members (tesa, Bill Hanlon, Gray_Ghost), 76 guests, and 0 robots.
Topics128,076
Posts1,055,925
Members48,430
#802025 11/30/2011 12:58 AM
looking for the "torque setting" for the differential bolts (pumpkin)? Mine is stock and original
torque values for everything are in the shop manual
Thanks for your reply. I saw that information in my shop manual, but was a little confused. Please help me identify the terminology used. Which category listed are the differential cover bolts?
After looking at some of those recommendations, it seems that I am not seeing the torque recommendation for the cover bolts. Some of those numbers seem high.
Thanks again for your help.
by the way, although I mentioned my 1957 truck was stock with the original transmission, additional information is that it is a 1/2 ton with 3 speed on the tree.
ahhh, the cover - don't think I've ever seen a spec for that, but any sheet metal with a cork gasket [like oil pan or valve cover] is usually about 5-10#, I'd make them "snug" without chancing distorting the cover
