7 members (dt235sd, 3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, 1 invisible),
88
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,074 Posts1,055,910 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 100 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 100 | looking for the "torque setting" for the differential bolts (pumpkin)? Mine is stock and original | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | torque values for everything are in the shop manualBill | | | | | Joined: Sep 2010 Posts: 100 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 100 | Thanks for your reply. I saw that information in my shop manual, but was a little confused. Please help me identify the terminology used. Which category listed are the differential cover bolts?
After looking at some of those recommendations, it seems that I am not seeing the torque recommendation for the cover bolts. Some of those numbers seem high.
Thanks again for your help.
| | | | | Joined: Sep 2010 Posts: 100 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 100 | by the way, although I mentioned my 1957 truck was stock with the original transmission, additional information is that it is a 1/2 ton with 3 speed on the tree. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | ahhh, the cover - don't think I've ever seen a spec for that, but any sheet metal with a cork gasket [like oil pan or valve cover] is usually about 5-10#, I'd make them "snug" without chancing distorting the cover
Bill | | |
