9 members (GMCJammer51, Materman, Lightholder's Dad, Ridgeback, Brian Moore, tclederman, jupitor, treegrower, 1 invisible), 189 guests, and 2 robots.
Topics128,080
Posts1,055,952
Members48,430
#80182 07/19/2007 4:33 AM
NEED ADVICE ON 1937 CHEVY PICKUP WITH 1954 235 ENGINE. WHAT RECOMMENDATION IS THERE FOR A FOUR SPEED MANUEL TRANSMISSION TO GO WITH 235 AND THE ORIGINAL CLOSED DRIVE SHAFT ASSUMING I CAN GET A RING AND PINION FOR A '37 IF I NEED ONE. WANT TO KEEP THE CENTER LINE OF ORIGINAL STICK. WOULD A '37 FOUR SPEED BE BEST OR SOME OTHER TO GO WITH THE 235.
It's not the speed you travel it's the quality of the trip that matters !!!
#80183 07/19/2007 4:52 AM
3B Online: Content
3 Online: Content
Hy ptc1937chevy, A lot depends on what you intend to do with this truck, the 37 transmission will handle the 235 well and is a drop in with the correct bellhousing, hope that helps.
#80184 07/19/2007 5:03 AM
A 37 fourspeed would have about the same ratios on the top three gears as your three speed with a creeper (granny) low gear which is only used when you are starting out with a heavy load or for creeping through a hay field, unattended, while you buck bales. Two disadvantages to it are that it is a crashbox (no syncros on any gear) and it is very heavy. You could use the later version of the early fourspeed that has syncros on the top three gears. The only close ratio fourspeed I have seen adapted to the torque tube is a Saginaw with a kit from patricks in Casa Grande, Arizona. Its disadvantage is that it is a side shifter, not a top shifter.
#80185 07/19/2007 5:38 AM
I was thinking 47-55 4 speed.Just want highway speeds 65mph.Would that be a good combo?
#80186 07/19/2007 6:02 AM
No different than the 3 speed that is in there, really. The final drive willstill be 1:1. You would also have to change the bellhousing because the 48-55 years used a different bolt pattern for the transmissions.
Your best bet is to lose the torque tube and swap out to an open driveline. It opens up many more possibilities. You don't need to get an overdrive transmission if you find a rear end with high gears like a 3.07 ratio. Many peolpe on the board have swapped T-5 transmissions from an s-10 in there prewar pickup. I believe that is one of the best choices for getting your old truck up to freeway speeds. The t-5 works best with lower gears... 3.55-4.11. Some people run higher gears, some lower. A stock 235 may have trouble pulling a hill with higher gears.
Cheers
#80187 07/19/2007 5:10 PM
Ford made a top shifter fourspeed with aluminum case and the fouth gear as overdrive that a couple of companies have modified for use in Model As with torque tube adapter. It was available only in 1984-1985 in six cylinder pickups. I would like to find one to have modified for my 1933 Chevy sedan.
#80188 07/20/2007 1:43 AM
You already have a modified truck with the 235 so why not take one more step and go open drive line with a T-5 trans so you can enjoy the ride?
Also when you get that T-5 installed you can make our Inliner's Picnic just down the road in Lodi, Sept. 9. Hope to see you there in any case.
1946 1/2-Ton Chevy
