0 members (), 35 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#801695 11/28/2011 10:15 PM
Hey I'm new to the forum. I have a 54 150. Just converted to 12v for winter driving. I know this has nothing to do with wiring.
When I fire the old girl up she will only run with the gas pedal flat to the floor. And at that only for a few seconds. I changed the condenser and added a alternator. Other than that, that's all I did in the engine bay. When it shuts down fuel spills out the overflow tube in the center of the carb. Could the carb be bad? The car ran great b4 the conversion
bgd54 #801700 11/28/2011 10:36 PM
It sounds like you carb float is stuck.
Mark
1951 Chevy 3100
Some days you get the bear. Some days the bear gets you.
51bolt #801704 11/28/2011 10:38 PM
When I put the float in. What way should the rear tab be facing? Up or down?
bgd54 #801758 11/29/2011 1:12 AM
The float operates the needle valve, so it needs to be put in so that when the float is up, the valve is closed, and when the float is down, it is open. You could connect a piece of plastic tubing to the fuel inlet and blow through it to test if it is open or closed as you work the float.
Kurt
bgd54 #801858 11/29/2011 6:54 AM
In most carbs the tab pushes on the needle valve, so up. Just remember though, up is down when the carb top is upside down on the work bench! wink
Also you might want to let everyone know what type of carb it is, it will help with the diagnosis. It does sound like the needle valve is not closing though. Is there pooled gasoline on the floor of the intake?
Sort of stock 1950 Chevrolet 3100
235 (The engine shread) (Engine assembly)- 4 speed - 12 bolt - stock front axle with power disc brakes
RingLeader #801962 11/29/2011 8:43 PM
Riding in the Passing Lane
Check the float to make sure it is not full of gas. If it is in correctly YOU must have dirt in the needle & seat.
1972 Chevy c10 Cheyenne Super
