0 members (),
136
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 71 | Hi all - installing 2 piece winshield and I wanted to make sure I am understanding instructions correctly. It says to apply 3m weatherstrip adhesive around pinchweld on windshield opening. It also mentions sealing glass to rubber seal. Does that mean to 3m weatherstrip the glass into the seal or is there some other kind of 'cement' to be used? Kind of vague on the instructions so I thought I would double check. Thanks!
1st Gen. Dodge Cummins 4x4 OVRTRQD Buick GNX #276 "If it died... we can fix it" | "If your not outraged, you're not paying attention." | "Do you know a large group of baboons is called a Congress? That explains a lot." ~author unwn
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I better not give advice on this, my windshield leaks. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | On my buddy's 53, I used the 3M bedding & glazing compound, worked great. It simply wipes off, so don't be stingy. I used 3M clear window sealer between the glass & rubber after installation. | | | | | Joined: Aug 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 71 | Thanks so much for the info. Was all ready to try that today but been fighting to just get the windshield in all afternoon and it never went in. Fought the rear window all afternoon the other day and never got that one in either. Beginning to think something is fishy. Window openings on cab? Glass pieces matched up... have tried the string method and the fid method. I think frustating is the word for today?
