9 members (Hotrod Lincoln, sron48, FAST55, Uncles51, gswbbc, Hanks custodian, 32Fordpuchoptop, Joe W, 1 invisible), 158 guests, and 1 robot.
Topics128,041
Posts1,055,479
Members48,424
#801555 11/28/2011 11:03 AM
Hi all - installing 2 piece winshield and I wanted to make sure I am understanding instructions correctly. It says to apply 3m weatherstrip adhesive around pinchweld on windshield opening. It also mentions sealing glass to rubber seal. Does that mean to 3m weatherstrip the glass into the seal or is there some other kind of 'cement' to be used? Kind of vague on the instructions so I thought I would double check. Thanks!
1st Gen. Dodge Cummins 4x4 OVRTRQD Buick GNX #276
"If it died... we can fix it" | "If your not outraged, you're not paying attention." | "Do you know a large group of baboons is called a Congress? That explains a lot." ~author unwn
Leo Offline
Moderator
Moderator
I better not give advice on this, my windshield leaks.
Leo #801714 11/28/2011 10:50 PM
On my buddy's 53, I used the 3M bedding & glazing compound, worked great. It simply wipes off, so don't be stingy. I used 3M clear window sealer between the glass & rubber after installation.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
OVRTRQD #801739 11/29/2011 12:14 AM
Thanks so much for the info. Was all ready to try that today but been fighting to just get the windshield in all afternoon and it never went in. Fought the rear window all afternoon the other day and never got that one in either. Beginning to think something is fishy. Window openings on cab? Glass pieces matched up... have tried the string method and the fid method. I think frustating is the word for today?
Moderated by  ndkid275, Phak1
