8 members (pauld, lumbersawyer, Gdads51, frogfarmer, J Lucas, carbking, Charles in CA, 1 invisible),
99
7
Mod | | | Forums66 Topics128,264 Posts1,058,358 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#80098 07/17/2007 6:44 AM | Joined: Dec 2003 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 62 | I searched, I know I saw it once before, but now can't find it. I plan to drill and tap, so as to put bolts through the front of the timimg cover. I saw someware(once), what size hole to drill, and size of bolt to tap for. I'm thinking that I need to drill & tap for a 3/8 fine thread bolt, (thinking becouse the original 5/16 bolts were fine thread. Does this sound right? Will the same size (20/64) drill, used to drill the cap to tap, be large enough to drill through the cover, and allow the bolts to slide through to the cap where they will screw in? Thanks. | | |
#80099 07/17/2007 8:16 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Here\'s how I did it. The existing holes in the bearing cap will tap as they are. I drilled my outer holes to 3/8" but it will line up easier if you go a tad larger. | | |
#80100 07/17/2007 5:30 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Great tip Cletis!!! One thing you might want to do before installing the 3/8" lower timing cover bolts is to grind down the height of the head....it will make it easier to drop the 7/16" driver's side motor mount bolt in from the top, especially if you've got the balancer installed and the engine is in the truck.
Dave | | |
#80101 07/18/2007 3:07 AM | Joined: Dec 2003 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 62 | I agree! Great tip Cletis! Dave, thanks for the heads up on the bolt heads! Thanks guys! Bryan | | |
