1 members (Hotrod Lincoln),
112
Mod | | | Forums66 Topics128,142 Posts1,056,491 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Does anyone know where these can be found? I managed to lose one of mine last weekend. My experience with other engines is that they're not something you'll find at the hardware store. I may go to a boneyard tomorrow and pull one out of a wreck but I wanted to know if they can be more easily had elsewhere. I'd like to try to start this engine tomorrow, if possible. If I do pull one out of a wreck, will any 235 do? My truck is a 56 1/2 ton.
1956 Chevy 3200
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 216s and 235s use the same head bolts.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Can anyone tell me which head bolts have the holes drilled in them for oil flow? I've read about them in some old posts but haven't seen a diagram or explanation of where these particular bolts are located.
1956 Chevy 3200
| | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | Only certain head/block combinations need the drilled head bolt. It's located in the center hole on the passenger's side, and the bolt has a slot in the top resembling one for a big common-blade screwdriver. Early-production heads have an oil line feeding the rocker arms, while later ones use a drilled oil passageway in the block and a corresponding one in the head. Certain combinations use the drilled bolt to complete the oil circuit to the rocker arms. Jerry
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | This LINK has a good explanation. Here is a Picture of a correct bolt.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | That is great information. Thanks for posting. It seems my engine did not have the drilled bolt, then. Will a 1/2-13 grade 8 bolt from a hardware store work? If not, it's off to the boneyard.
1956 Chevy 3200
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you go to a parts yard to get the bolts out of an engine, make sure it is a 18-bolt head; or, if you find a 15-bolt head (216 or earlier 235), get your eighten bolts (two different sizes of bolts) from two engines.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If you can find the correct length, I see no reason a grade 8 bolt would not work.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | Whatever company took over the old "Dorman" automotive hardware brand has head bolts listed for a lot of engines. Not sure about stovebolts, though. A really good FLAPS or a professional rebuilder should have access to their products. Jerry
| | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Just got back from the boneyard. Lots of old Mopars there but no 235s. My local Fastenal has the grade eight bolts at the right length so I think I'll try one and see how it works.
1956 Chevy 3200
| | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Well the grade eight 1/2-13 X 4 1/2 worked like it was meant to be there. It slipped right in and I torqued it down with the rest of them, so it seems like this is an option for those of you who wind up missing the odd head bolt.
1956 Chevy 3200
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That is great information. I am becoming a real fan of that store. I picked up a nice sheet of 18 gauge there. I would have never thought about going there for that bolt. | | | | | Joined: Jun 2011 Posts: 117 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 117 | My engine showed up from the machine shop with a missing main cap bolt. Went down to fastenal and got a grade 8 bolt. No problems. I wouldn't hesitate to do the same for the head. | | | | | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | My engine showed up from the machine shop with a missing main cap bolt. Went down to fastenal and got a grade 8 bolt. No problems. I wouldn't hesitate to do the same for the head. On a 216,235 0r 261? Other than the rear main, the main caps are only located by the shoulder near the top of the bolt.Without the proper bolt the main cap can fret around and might cause a bearing failure. | | | | | Joined: Jun 2011 Posts: 117 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 117 | On a 235 rear main, one of the 4 was missing. | | | | | Joined: Jan 2004 Posts: 188 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 188 | If you want a chevy bolt, call Jim Carter. I'll bet he has one. | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | That is great information. Thanks for posting. It seems my engine did not have the drilled bolt, then. Will a 1/2-13 grade 8 bolt from a hardware store work? If not, it's off to the boneyard. To make certain, your bolt purchase from Fastenal completed your set, but you didn't have a modified bolt? Red flag went up... I would think you need one at the location mentioned in the other posts. Did I mis-read that? Jerry | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | What I understood from reading old posts was that it was used in early inline sixes (before '56) and then to accommodate oil flow when a head from one engine was used with the block of another (later years).
1956 Chevy 3200
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Your 56 engine will not need one.
