| | | Forums66 Topics128,261 Posts1,058,344 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 21 New Guy | | New Guy Joined: Mar 2006 Posts: 21 | Hey guys, is there anything such as just a "bolt on" IFS for a 57 3100 series; or do will I have to do fab. and welding? Also, can someone tell me what donor trucks I can use for the conversion, because I cant afford to buy a new kit, like Mustang II? I'm not the greatest welder, so doing a clip is out. Thanks. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Any IFS for the Task Force trucks will require fabrication and welding. Closest to a "bolt in" will be the '73-'87 Chevy full size truck, as the crossmember for suspension can be taken out of the donor truck in one peice. it would need narrowed to fit the TF chassis, plue you would need to fabricate steering box and idler arm mounts.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | The 73-87 is not wide enough for a Task Force,you might be able to use one from a full size van.I have one from a 78 pickup under my 48.I had to use a 3/4 in. spacer on each side.I made a template of the bolt holes from the 78 and transfered them to the 48.
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The 73-87 is not wide enough for a Task Force The '73-'87 is 5" wider than the Task Force.
