2 members (Gray_Ghost, Joe W), 211 guests, and 2 robots.
Topics128,108
Posts1,056,231
Members48,436
#800112 11/23/2011 12:23 AM
7
7 Offline
My 65 has a 283 with a powerglide trans. The transmission is leaking bad. It looks like the pan is leaking and there is a leak coming from the dust cover that covers the flywheel. I am building the truck to sell I thought about putting a standard in it. Which would sell better an auto or standard? Also how hard are the leaks to fix?
79broncoowner #800234 11/23/2011 5:27 AM
Pull the transmission and reseal it and install a new pan gasket. For the cost of parts & labor, to convert from an automatic to a manual (done properly & workmanlike), you can rebuild the factory-correct Powerglide and retain the originality of the truck.
I have converted several from manual to automatic, at the truck owner's request, but never had a request to convert a factory automatic to a manual. When doing so, the cross member, column, shift method & drive shaft must be changed...if the conversion is done to maintain the equity or originality of the truck. There were far fewer automatics put in these trucks, as compared to 3-speed and 4-speed manual transmissions, so finding an original, that hasn't been molested, with the original 2-speed Powerglide automatic, is hard to find.
I agree with Tony, Id leave the auto in.
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
jon1963 #800425 11/23/2011 9:15 PM
Riding in the Passing Lane
I believe the auto trans will have better resale value. Myself I prefer a manual trans but its amazing how many people out there can't drive one.
1972 Chevy c10 Cheyenne Super
7
7 Offline
Yeah thats what I thought about reselling the truck the auto would be better. I checked prices on gaskets for the powerglide and they were not to bad. Both my trucks I drive are four speeds and I really like them. If I was going to keep the truck I would go with a standard.Thanks for the replys
79broncoowner #801263 11/27/2011 3:56 PM
You've got the late-model Powerglide with the aluminum case, which, other than being short one gear, is a pretty good transmission. They have been highly modified for drag race and circle track use and worked very well in both applications.
It's not the ideal truck transmission, but for a weekend cruiser or a daily driver, I think it would be wise to leave it "as is".
