| | | Forums66 Topics128,080 Posts1,056,063 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | I replaced the rear axle pinion seal on my truck and figured while I was under there I should tighten up every bolt. Well, glad I did because one of the drive shafts (I have 3) had very loose nuts. Same with some of the exhaust bolts. So a word to the wise, tighten those bolts every once and awhile!
Do you guys use lock-tight to keep bolts in place? I have lock washers, but those obviously don't do the job. | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I just check on everything when I grease the truck, you know, give everything a shake to see what's what. I had a '63 Land rover that would loosen the driveshaft to joint connecting bolts every 4000 miles. It wasn't a problem, as before I could drive that far, I'd be underneath the truck fixing something else and snug them up on the way by. | | |
