1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#800032 11/22/2011 6:41 PM
I replaced the rear axle pinion seal on my truck and figured while I was under there I should tighten up every bolt. Well, glad I did because one of the drive shafts (I have 3) had very loose nuts. Same with some of the exhaust bolts. So a word to the wise, tighten those bolts every once and awhile!
Do you guys use lock-tight to keep bolts in place? I have lock washers, but those obviously don't do the job.
I just check on everything when I grease the truck, you know, give everything a shake to see what's what. I had a '63 Land rover that would loosen the driveshaft to joint connecting bolts every 4000 miles. It wasn't a problem, as before I could drive that far, I'd be underneath the truck fixing something else and snug them up on the way by.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
