2 members (Otto Skorzeny, Johnny N), 82 guests, and 0 robots.
Topics128,076
Posts1,055,924
Members48,430
#799555 11/21/2011 1:35 AM
I pulled my drive shaft to replace the differential u-joint. That part went great! Now that I tried to slide the shaft back into the tranny, it stops short about 5/8 of an inch and will not slide all the way in. Any ideas why?
Darren
1969 Chevy C-10 Fleetside
ODSS Lawman
ODSS Lawman
Are the shafts on the new and old u-joint the same length? If the newer one is longer it would explain why it seems like its not in all the way.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Sweet, I think you are assuming it to be a torque tube style rear end. I saw his signature shows a 69 model so it will be open driveshaft. If you turn the driveshaft 180 degrees, does the front yoke go in any further? It came out, you have to assume that the same parts would go back together the same way.
Greg_H, I didn't rotate the shaft fully 180° after the first try, but I did rotate it a few degrees, then a few more. Each time I got the same result. The shaft will stop with a thud with about 5/8 of an inch to go..so neither the hanger bearing nor the rear u-joint will line up where they need to be. Is there any possibility that the splines have only one position that will mate properly with the transmission?
Darren
I got nothing here. I can't say that I have ever seen one that was one way only but that doesn't mean much. Any chance that a needle fell into the end of the driveshaft front yoke?
H Online: Content
Pull the shaft back out and shine a light into the slip yoke. There's almost got to be something in the yoke that is keeping it from sliding all the way into position.
The slip yoke mystery has been solved...I wasn't holding the shaft quite high enough as I was sliding it forward. The hanger bearing was catching on the botton part of the frame thingie it passes through. Lesson learned!
Darren
