1 members (baldeagle),
27
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79898 07/12/2007 6:31 PM | Joined: Apr 2007 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 82 | I have seen mentioned that when timing the engine look through the bell housing and line up the needle with the BB. I have seen the BB referred to as a ball bearing. So my question is, how big is this? A ball bearing or a bee bee ? | | |
#79899 07/12/2007 7:06 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Purney,
It is about the size of an old fashioned BB. There may be other marks on either side of it. When you find it, give it a blast with some brake-clean or something and maybe paint it yellow with a small metal-marker. If you are going to use a timing light, both the BB and the tip of the sharp little pointer show up much better when cleaned and painted.
Stuart | | |
#79900 07/12/2007 8:04 PM | Joined: Apr 2007 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2007 Posts: 82 | | | |
