8 members (jaycoop, WICruiser, Joe H, 2-Ton, Southerntruck, TUTS 59, Bill Hanlon, Ponchogl), 118 guests, and 2 robots.
Topics128,129
Posts1,056,362
Members48,441
#7982 06/18/2002 5:57 AM
Y
Y Offline
Is anyone running power steering and AC on a 292? If so, do you have any pics of the setup/brackets? I have a 65 C10 with the 292 and have an AC bracket setup that puts the compressor at front/top of engine. I would like to add PS and already have the box and pump, but haven't seen brackets that would work. If Vintage Air has an AC bracket for a smaller compressor and I could get a bracket for the PS pump, I'd prefer that route. Anyone gone this route or something similar (PS and AC on 292)?
Rick
CA Central Coast
65 C10, 292, SM420
Rick
65 Chevy C10 Fleetside
Rick,
I installed power steering on a 1966 C60 with a 292. I bought a bracket and pump off a mid '70s Chevy pickup at a local salvage yard. Since my 292 has an early '70s head on it(small sparkplug), I felt it would line up better.
I still had to engineer the bracket so it would fit over the exhaust manifold and line up the pulley grooves. It mounts the pump high on the drivers side. I have not seen a 292 with both air and power steering. I find it difficult to beleive they would share a common bracket but then again I have never seen one.
Good Luck,
BigMac
Thanks Dan
I don't know about a 292, but I was looking at a 250 in a big ol' Chevy wagon in the boneyard this weekend. The P/S pump had been removed, but was sitting next to the engine with the bracket. The alternator was low on the block, the P/S pump was apparently above that, and the A/C was high on the opposite side of the engine, near the distributor. I think I may go back sometime this week and pull a few parts for my own 250 project.
1954 GMC De Luxe COE
Y
Y Offline
Thanks for the info guys! GMCpanel, any chance you could get a picture of the setup? Better yet, if you won't be needing the PS pump bracket or the AC bracket, I would be interested. They may very well work on the 292. Let me know what you find out.
Rick
65 C-10, 292, SM420
Rick
I've heard that the brackets are very different between the 194/230/250 and the 292. Also, I don't have a camera (digital or otherwise) at this point. My 250 has the correct pulleys for the full accessory package, so I can try to get a picture if I get the parts. Even with the different brackets, I imagine the positioning of the accessories would be similar. Try the guys over at Inliners.org, they have tons of good info on anything inline.
Y
Y Offline
Thanks GMCpanel, I guess I'll have to do little more research. Hopefully, I can reach the end goal.
Rick
Rick
Try this topic, it has some more info: 292 topic
