7 members (Southerntruck, jaycoop, Joe H, WICruiser, 2-Ton, 42465967, Shade Baby),
114
Mod | | | Forums66 Topics128,129 Posts1,056,362 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 6 Member | | Member Joined: Aug 2001 Posts: 6 | Is anyone running power steering and AC on a 292? If so, do you have any pics of the setup/brackets? I have a 65 C10 with the 292 and have an AC bracket setup that puts the compressor at front/top of engine. I would like to add PS and already have the box and pump, but haven't seen brackets that would work. If Vintage Air has an AC bracket for a smaller compressor and I could get a bracket for the PS pump, I'd prefer that route. Anyone gone this route or something similar (PS and AC on 292)?
Rick CA Central Coast 65 C10, 292, SM420
Rick 65 Chevy C10 Fleetside
| | | | | Joined: May 2000 Posts: 31 'Bolter | | 'Bolter Joined: May 2000 Posts: 31 | Rick,
I installed power steering on a 1966 C60 with a 292. I bought a bracket and pump off a mid '70s Chevy pickup at a local salvage yard. Since my 292 has an early '70s head on it(small sparkplug), I felt it would line up better.
I still had to engineer the bracket so it would fit over the exhaust manifold and line up the pulley grooves. It mounts the pump high on the drivers side. I have not seen a 292 with both air and power steering. I find it difficult to beleive they would share a common bracket but then again I have never seen one.
Good Luck,
BigMac Thanks Dan | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I don't know about a 292, but I was looking at a 250 in a big ol' Chevy wagon in the boneyard this weekend. The P/S pump had been removed, but was sitting next to the engine with the bracket. The alternator was low on the block, the P/S pump was apparently above that, and the A/C was high on the opposite side of the engine, near the distributor. I think I may go back sometime this week and pull a few parts for my own 250 project. | | | | | Joined: Aug 2001 Posts: 6 Member | | Member Joined: Aug 2001 Posts: 6 | Thanks for the info guys! GMCpanel, any chance you could get a picture of the setup? Better yet, if you won't be needing the PS pump bracket or the AC bracket, I would be interested. They may very well work on the 292. Let me know what you find out.
Rick 65 C-10, 292, SM420
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I've heard that the brackets are very different between the 194/230/250 and the 292. Also, I don't have a camera (digital or otherwise) at this point. My 250 has the correct pulleys for the full accessory package, so I can try to get a picture if I get the parts. Even with the different brackets, I imagine the positioning of the accessories would be similar. Try the guys over at Inliners.org, they have tons of good info on anything inline. | | | | | Joined: Aug 2001 Posts: 6 Member | | Member Joined: Aug 2001 Posts: 6 | Thanks GMCpanel, I guess I'll have to do little more research. Hopefully, I can reach the end goal.
Rick
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Try this topic, it has some more info: 292 topic | | |
