1 members (baldeagle), 40 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#798538 11/17/2011 12:43 AM
Looked thru the casting info and on line,but still can't figure it out. This motor is not an intregal head, so I know its before 1975.The # on the flat pad behind the distributor is F1102TAB. Cast into the side of the block is CON 2 J233 and 328575 with GM under that,and 86 under the GM. 32875 meaans this is a 68-84 block?
Does the J233 mean it is Oct/23/1973??? I was told it is a 250.
tmcculley #798702 11/17/2011 4:49 PM
I would guess the date code is Oct/23/73, but, they are all the same so it really doesn't matter. Pick a year when buying parts and stick with it, no need to confuse the counter guys. All the heads were the same for the 230,250, and 292's. I believe all 230 and 250 blocks are the same.
Joe
Joe H #798719 11/17/2011 6:13 PM
Riding in the Passing Lane
There were non-intregal heads used on some models after 75. Mostly on Cameros.
1972 Chevy c10 Cheyenne Super
Wrenchbender Ret. #798804 11/18/2011 12:58 AM
F1102TAB
1970
Made in flint
11th month
02 day built
T Truck engine
AB 250cu in.
155 HP
8.5:1 comp. ratio
1BC carb.
Manual trans
Pete
Pete52 #798835 11/18/2011 3:12 AM
So its the flat pad behind the distributor that tells all.Where do you get the 1970 from?Where did you find your magic info, Pete ?Thanks everyone.
tmcculley #799135 11/19/2011 5:24 AM
In cars& parts book of chevy truck ID numbers 1947 to 1972
1970 was the only year that chevy used the AB part of you're number on the 250 cu.in. 6.
Pete
