6 members (Mike B, klhansen, TUTS 59, Otto Skorzeny, Shaffer's1950, Peggy M), 103 guests, and 2 robots.
Topics128,123
Posts1,056,653
Members48,450
#784972 09/30/2011 2:38 PM
Were seat belts offered in 1961 on Chev trucks?
They were certainly offered as accessories. The following is from the 1960 Accessory Installation Manual:
[IMG]http://img716.imageshack.us/img716/984/1960accessories103.jpg[/IMG]
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
They were first offered by GM in 1956 (at least in cars).
Optional until 1965 and then them became mandatory, as dictated by the Feds, in 1966.
Thanks,my truck doesn't have them but I'll be putting some in.Any suggestions as to the "most cost effective" kit out there?
in Canada mandatory as of dec.31,1963
ron
My 61 has no seatbelts either but I'd like to put some in...preferrably shoulder belts...I did a bit of research, and it seems my truck (or any vehicle) is actually safer with no seatbelts at all than with lap belts. Has anyone ever heard of shoulder belt kits that are made to fit these old trucks?
I used these in my 64.
Seatbelt Planet
Install went smooth and they are good quality belts. Only tricky part is feeding the backing plate up inside the pillar. I taped the plate to some 1/8" steel rod and then pulled the rod out after torquing the anchor bolt down.
Dracko, so, no welding involved? was it just a matter of drilling a hole in the inside of the pillar, and then feeding the plate up from the bottom (behind seat right by the tank) and threading the bolt through it once you had it lined up with the hole?
Quote
Yeah that's exactly how I did it. was actually an easier install than I expected...don't say that very often. grin
I would have to disagree with the assertion, that no seat belts at all are better than lap belts. With no crumple-zones, energy-absorbing materials, dash padding or air bags, in the cab of a '66 Chevy truck, I have been glad to have my antiquated lap belts, to keep me in the cab in a few instances, over the years.
Shaweeet! Looks like I'll be ordering s set of those smile
I have owned 3 Canadian built trucks, a '64 Chev, a '65 Chev, and a '66 GMC that did not have factory seat belts.
Installed them in the '65 at my Dad's insistence, wrecked that truck, then installed the same belts in my '64 (which used to be my Dad's) as by that time I was the Dad and had 2 little guys to worry about.
Garry
