| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | I have noticed that Autozone, Napa, Advance, and the rest in MO have quit selling Clutch parts for our bolts. Will a 11" clutch fit into my 46 1.5 ton? What kind of flywheel would I need and how many teeth fo 6 volt?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Lend-Lease 1.5, according to my Fenco clutch book your truck probably came with a 10 3/4" clutch, their p/ns pressure plate Heavy duty CA342W, standard duty CA342A, clutch disc CP753, these would be nine bolt pressure plates, hope that helps | | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | There are shops out there that can add new friction material to the disc if you want to reuse the old one. I had to go this route on one of my old trucks.
Look for a clutch and brake specialty shop in your area.
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | 'Clutch Exchange' in Denver has done some for me.
| | | | | Joined: Feb 2011 Posts: 19 New Guy | | New Guy Joined: Feb 2011 Posts: 19 | I used an 11" disc in my 50 1.5 ton dump truck, I checked all the measurements of the center hub section pretty closely to make sure nothing would hit or rub, there was enough clearance for the +1/8" per side radially, of the diameter increase from 10 3/4" to 11".
50 chevy 2-ton dump 71 C-20 Suburban 402/400 72 C-10 Suburban 350/3-speed | | |
