3 members (delky, Hotrod Lincoln, Rich'sToys), 78 guests, and 0 robots.
Topics128,049
Posts1,055,740
#793041 10/28/2011 1:43 PM
I have noticed that Autozone, Napa, Advance, and the rest in MO have quit selling Clutch parts for our bolts. Will a 11" clutch fit into my 46 1.5 ton? What kind of flywheel would I need and how many teeth fo 6 volt?
Lend-Lease 1.5 #793199 10/28/2011 11:37 PM
3B Offline
Hy Lend-Lease 1.5, according to my Fenco clutch book your truck probably came with a 10 3/4" clutch, their p/ns pressure plate Heavy duty CA342W, standard duty CA342A, clutch disc CP753, these would be nine bolt pressure plates, hope that helps
3B #793210 10/29/2011 12:11 AM
There are shops out there that can add new friction material to the disc if you want to reuse the old one. I had to go this route on one of my old trucks.
Look for a clutch and brake specialty shop in your area.
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
sleeve #795181 11/04/2011 5:58 PM
Crusing in the Passing Lane
'Clutch Exchange' in Denver has done some for me.
EdPruss #798178 11/15/2011 7:07 PM
I used an 11" disc in my 50 1.5 ton dump truck, I checked all the measurements of the center hub section pretty closely to make sure nothing would hit or rub, there was enough clearance for the +1/8" per side radially, of the diameter increase from 10 3/4" to 11".
50 chevy 2-ton dump
71 C-20 Suburban 402/400
72 C-10 Suburban 350/3-speed
