| | | Forums66 Topics128,014 Posts1,055,328 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 22 New Guy | | New Guy Joined: Nov 2011 Posts: 22 | Need info .The areas around the wheel well of my 58 needs body work . most of the work frome the spear up i can handle, but does anyone have a sorce for replacement meatal for around the wheel well area.Is there any other year bed that panels would be able to be removed and welded to the 58 bed [there in rough shape ] TONY | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | chevman1: MAR-K has a wheelhouse repair flange. Here is the description: Wheelhouse tub flange to repair rusted or damaged area of wheel tub where it meets the wood floor. 16-gage electro-galvanized steel flange has bed strip embossment like original. Instructions included. Requires 2 flanges per truck. Made in Oklahoma City, USA. This should take you to the part online. http://www.mar-k.com/Catalog/itemDetails.aspx?ItemID=100585Hope this helps! | | | | | Joined: Nov 2011 Posts: 22 New Guy | | New Guy Joined: Nov 2011 Posts: 22 | Thanks for that info. Im looking for repair panels for the out side of the bed around and including the center and sides of the outer wheel area.I can find repair pannels fo the stepside but not the fleetside .TONY | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | there are no patches made for the fleet wheel opening, although you could cut some from a stepside fender, which has a very close shape for the molded edge
Bill | | | | | Joined: Apr 2001 Posts: 199 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 199 | How much of the wheel opening do you need? I am cutting up a fleetside bed to make into a dually bed. The bed I have has rust in the spear section above and behind the wheel. but is solid around the wheel opening itself. How soon would you need them? I was going to save them in case I ever needed one but that day may never come. | | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | I would compare to the 60-66 sheet metal below the 'spear'. I think the wheel opening is close but I no longer have a 60-66 to check against my 59. I do have a 60-66 tailgate on my 59 fleet and it's he same. The patches are available for the 60-66 wheel openings but at a minimum you would have to take some off the top.
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
