1 members (Otto Skorzeny),
201
Mod | | | Forums66 Topics128,091 Posts1,056,387 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 38 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 38 | Hi guys My 61 suburban's rear floor is covered top and bottom with a black hardened tar like substance. Pretty sure this is not how they came from the factory. I assume it is wood, but is it like a pickup bed or is it more like some sort of plywood? Any thoughts on what is the best approach to replacing it? Thanks Dale
Remember, for every mile of road, there's two miles of ditch! If you fall on your face, you're still moving forward.
| | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | its plywood, they came with ribbed rubber flooring. you have to unbolt all the sides and cross members and lift body! lotta work | | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | mine was ok, when i ordered the carpet kit i ordered extra raw carpet, cut it out to fit and had a carpet place bind the edges for $20. PS i have an extra floor! | | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | the plywod is a full 1" thick. | | | | | Joined: Oct 2011 Posts: 38 'Bolter | | 'Bolter Joined: Oct 2011 Posts: 38 | Thanks I guess my first step is to remove the black tar like stuff and see what is actually there. Thanks again Dale
