2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#797771 11/14/2011 12:23 PM
Hi guys
My 61 suburban's rear floor is covered top and bottom with a black hardened tar like substance. Pretty sure this is not how they came from the factory. I assume it is wood, but is it like a pickup bed or is it more like some sort of plywood? Any thoughts on what is the best approach to replacing it?
Dale
Remember, for every mile of road, there's two miles of ditch!
If you fall on your face, you're still moving forward.
its plywood, they came with ribbed rubber flooring. you have to unbolt all the sides and cross members and lift body! lotta work
mine was ok, when i ordered the carpet kit i ordered extra raw carpet, cut it out to fit and had a carpet place bind the edges for $20. PS i have an extra floor!
the plywod is a full 1" thick.
I guess my first step is to remove the black tar like stuff and see what is actually there.
Thanks again
Dale
