| | | Forums66 Topics128,080 Posts1,056,062 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2011 Posts: 99 Shop Shark | | Shop Shark Joined: May 2011 Posts: 99 | I recently removed the bed wood on the truck and am trying to figure out what this is. http://imageshack.us/photo/my-images/856/img4778z.jpg/My truck is a 1955 1st series. This is mounted on the axle pointing up. Anyone know what this is? Thanks | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'd guess it is a mount for an after market booster spring. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Aftermarket coil spring overloads used a contraption like this. | | | | | Joined: May 2011 Posts: 99 Shop Shark | | Shop Shark Joined: May 2011 Posts: 99 | I was guessing it had some sort of coil spring on it. I guess its one more thing for me to take off Thanks | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | May have had a conical rubber bump stop mounted in the hole as well.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
