2 members (ShopRag, DaveV),
97
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 8 New Guy | | New Guy Joined: Dec 2009 Posts: 8 | 54 panel body,fenders doors,grill only,no frame,axles,motor etc. all patck work done,front floors. stripped primed and rust free. no title what would be a fair offer to help out a friend? | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | For a friend, from the buyer's perspective, all you can afford. For a friend from sellers perspective, as little as he can afford.
Now if you ask about value I would think if the body is in completed condition, that is every rust out patched and rust free probably somewhere between 3K and k4. The hood might be a bit hard to find as 54 and 55.1, I believe will be the only hoods that will fit. You could buy a trashed AD for the frame and other parts. It could become an expensive project if you don't have a parts vehicle. Of course you could try using the part truck's title but that might not work. Here in Texas a panel truck is a truck so why not? Otherwise you'll have to file for a new title. Good luck!
~Jim
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | 1/2 ton or 1 ton body?
Bruce | | | | | Joined: Dec 2009 Posts: 8 New Guy | | New Guy Joined: Dec 2009 Posts: 8 | its a half ton body (short) i do happen to have a 54 1/2 ton frame to put it on. i was thinking 1,000 to 1,500 | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | a friend of mine sold one recently for $3K - rust free and complete. This was in NH, where you can hear old sheetmetal rust... | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Look around an see if you can find a panel. Compare its condition vs the price. You can expect to spend a lot of time and money in patch panels and mig wire to bring it to the prime condition of the one you are looking at. The tear-down is a lot of work and so is all the work that has already been done.
~Jim
